Winter project #2
Daily report: bike sat overnight, garage 15C, tried white, warm start button depressed, full choke, no throttle, 4 kicks and not a fart. 10 kicks with decompression, full choke, 4 kicks, no farts. 5 kicks with decompression, 1st kick with no choke, no warm start button and no throttle - started very low idle and died. Subsequent kick nothing. Third kick low idle and died (before I could apply any choke). Last attempt - choke lever all the way down and back up maybe halfway. 1st kick running happily.
My takeaway - theory #225 - needs cold start choke to start and run; full choke is too much; partial choke may be the answer but I need to find the sweet spot and make application to that spot repeatable. I should be able to make a stop for the lever or plunger.
...partial choke may be the answer but I need to find the sweet spot and make application to that spot repeatable. I should be able to make a stop for the lever or plunger.
I'm happy to hear you are getting closer to the "formula". IIWY, I might be slow to create a stop, as you may find the bike likes different choke settings depending on ambient temperature? My XS behaves differently at first start at different temps.
I tried to start it tonight with the same choke setting as this morning. No go. Back to square one, which I think will be a different, rebuilt carb.
Spare carb disassembled. Quite a few bits. Will start cleaning the pieces soon. Carb kit is on its way but has a Dec 2nd delivery ☹️.
The fuel tank filter lid had a torn seal. Replacements are quite expensive. I’m guessing close to $50-$60. I looked in my parts stash and found a new one, that I had purchased for the XS in error. I love it when things like this happen.
Compared carb innards and both the carb on the bike and my spare had the same part numbers. The slide in the bikes carb had some damage and looks like the po pried open a stuck slide, messed up the cutaway and tried to clean up the damage with a die grinder or file. He messed it up so I swapped out the slide from the spare.
At the bottom of the bowl there’s a ball bearing pushed into a drilled passage and the sealer is coming off. I’m sure it will be gone after I put it in the ultrasonic cleaner. I’ll have to smear some goop on it.
The mixture screw needed to be backed out over 3 turns. This tells me the pilot jet might be on the small / lean side. Stock is 25. I have a 27.5 from my XS parts stash that I’ll try.
I’ll clean everything up but reassembly will have to wait until rebuild parts arrive Dec 2nd ☹️
I decided to remove the exhaust to do several things. Look at the valves; weld shut two of the header vent holes and clean up the exhaust. The one nut holding the header on came off easily. The other pulled the stud out of the head. In the vise with heat and the nut would not come loose. I just about gave up for the day but just got the hell of it trued generation hack to free up frozen fasteners. I was a non believer but it actually worked. I’ll clean up the threads and mount the stud back in the head.
Inspection of the valves revealed I have a problem with the intake valve. Either a valve stem seal or guide. I might do a top end refresh.
I just about called it a night but decided to spend 15-20 minutes cleaning up the muffler. Turned out well and looks great from 6 feet away.
That’s all for today.
On to the pics..
IMG_6023.jpegIMG_6024.jpegIMG_6025.jpegIMG_6030.jpegIMG_6031.jpegIMG_6029.jpegIMG_6039.jpegIMG_6040.jpegIMG_6038.jpegIMG_6034.jpegIMG_6037.jpegIMG_6043.jpegIMG_6049.jpegIMG_6051.jpegIMG_6050.jpegIMG_6054.jpeg
New discovery. When messing with the air box to facilitate re/re the carb I noticed the battery box wasn’t securely fastened. Turns out the p.o cut off the top brackets for some unknown reason. The battery box/ tray was left sitting on two rubber mounts with only gravity holding it in place. Attached to the box is the rectifier and CDI unit. Then I thought doesn’t the CDI module need to be grounded? If it does, the only way it could find ground was through the rectifier body. If this is the case - could this contribute to not so consistent spark? I’m rebuilding the box and will make sure the module is well grounded. Maybe I’m onto something? Maybe not?
Cardboard template to make bracket tomorrow.
Dirty old chain guard cleaned up. 👍🏻
IMG_6089.jpegIMG_6088.jpegIMG_6087.jpegIMG_6086.jpegIMG_6082.jpegIMG_6084.jpegIMG_6085.jpegIMG_6078.jpegIMG_6079.jpegIMG_6080.jpegIMG_6081.jpeg
My plans to “fix” my cut up battery box might be changing. Looking at an unmolested box on line, the box is held in place by three rubber cushions. The top frame of mine is cut off and the third mounting point is gone. I had planned to weld a bracket to the top of the box and bolt it to the frame. That would make the mount quite rigid and subject the battery to lots of vibration. Is this a bad plan? Does the battery need to be suspended in rubber mounts?
If rubber mounting is necessary I can look for a used battery box or try to incorporate a rubber piece in my planned rework.
My take , Batteries dont like vibration but some tolerate it better than others. I have discovered the hard way that Motobatt batteries cant handle vibration they break inside. I have seen this a few times on classic race sidecars.
Asea batteries made for quad bikes can handle the vibration.
I would try to reinstate the rubber mounting however the SR has a CDI so the motor should run with no battery.
Thanks I have a plan to add a top point of attachment that has some rubber in it. I was thinking if the battery bounces around too much I might put an AGM battery in the bike. Apparently they can tolerate more vibration.
I might put an AGM battery in it regardless...get rid of the vent.
No shortage of surprises today. I was preparing to replace the valve stem seals and drained the oil. There’s three places: the sump, front down tube and frame back bone (oil tank). The oil capacity is around 2.2 L. This is what drained out😳
When I bought the bike, the top tank was empty. The po gave me 2.5L of oil so I figured they started an oil change and hadn’t added oil. I put in the prescribed 2.2L and it registered right on the full mark. Now that I’ve drained this much oil out, I put on my detectives hat and figured out what happened. I’ve never had a dry dump engine before and didn’t know that if stored for a long time, the oil can possibly drain from the tank to the engine sump. I believe that’s what happened to me. I’m wondering if that where the oil deposits came from on the internals? Oh well it’s done and hopefully won’t have to come apart again.
I read that I should be able to remove the rocker cover with the engine in the frame. I think you need to be Houdini to do it. No way the cover would clear the long studs. I ended up pulling the engine.
In the long run it was a good idea because getting at the stem seals would have been next to impossible to service with the engine in the frame. The double valve springs were a bugger to compress to get the keepers out. Two times the keepers went flying across the garage and I was super lucky I was able to find them. I replaced the intake seal and decided to do the exhaust side at the same time. There was no way to use a conventional spring compressor so a long box end wrench and 19mm combination wrench were used to McGyver the keepers in and out. Not easy.
The rocker arms, cams and bearings all looked good. I’ll slather on some Hylomar sealant tomorrow and torque the rocker cover back on.
With the motor out it gives me a good opportunity to clean the frame and apply some touch up paint.
Damaged jam nut - the po was a butcher. See how hacked up the cam chain tensioner jam nut was from using and improper wrench. Box end of a 22mm is needed. Damage had been cleaned up and the nut is usable.
IMG_6099.jpegIMG_6100.jpegIMG_6102.jpegIMG_6103.jpegIMG_6109.jpegIMG_6112.jpegIMG_6114.jpegIMG_6116.jpegIMG_6117.jpeg
the oil can’t possibly drain from the tank to the engine sump. I believe that’s what happened to me.
It can. It's called "wet sumping." About every dry sump engine I ever worked on has a check valve on the sump to oil tank line. oil can return to the tank, but the check valves stops it draining back into the sump. At least that's the theory. 'Bout every one I worked on also leaked back into the sump anyway.
Just get into the habit of checking the oil soon-ish after running it and give it 10 or 12 kicks to sump the oil out if it's sat a week or so.
There is a spring loaded check ball and seal inside the clutch cover that prevents the oil from draining into the sump. They leak when the seal gets old. When you change the oil you need to drain the sump, the frame and the filter area. Yamaha used to suggest that you elevate the rear of the bike some to completely drain the frame. I usually put a block of wood under the rear wheel to accomplish that task. When you refill the oil maybe put in a quart and a half in and run the engine for a couple of minutes, then top it off. Also, that little screw on top of the oil filter cap is for venting trapped air in the oil filter cavity. Before you start the engine it is suggested to remove the screw and kick the engine over until oil comes out of the hole. I usually just loosen it a few turns and start the engine to accomplish this. Don't take the screw out and start the engine though, or you will be cleaning oil off your ceiling in the shop. Oil changes are another ritual with the SR. Have fun.
Thanks Jim - fat fingers. Meant to type “can drain”.
Bob is this seal replaceable without disassembling the motor ?
