Lucky find! I have looked for one locally in the past, either an SR or an XT, without success. I am at the point where I have so much on my plate as it is that I think I just need to put that thought out of my mind. Enjoy your SR!
Just found out they’re still available new. I wad thinking someone could probably 3D print one?What are my options for replacing this rubber insulator (between chrome housing and Speedo). It decided to come apart in two pieces. I don’t think there’s enough left to glue together.
View attachment 377330View attachment 377331
Kedo sell all sorts of parts for Yamaha XT/TT/SR bikes.
https://www.kedo.com/catalogsearch/result/?q=SR500
Hi Bob, I had a look on mine and the button is just threaded and can’t be pushed up. Maybe you have a newer model? Thanks.bosco659, That little white button on the left side of the carburetor, where you adjust the idle speed, is for starting the engine when it is warm. Press it up and it will click. It opens the throttle plate to the correct position for warm starting. You don't need to open the throttle with the twist grip. Once started rotate the throttle in the closed direction to return button to the closed position. Works real good. At least on my SR.
Cool looking bike. I couldn’t ride it with the clip ons. The Smiths instruments look great. If that girl can kick it over I should be able to with me having over twice her weight. lol. But it’s about technique too. Practice needed! Thanks for the vid Marty!FWIW, here’s a YouTube channel with lots of SR500 content. Much of it lifestyle. Good for long Canadian winter.
https://youtube.com/@yutube123?si=WueiimMgw2UQtr6h
That’s essentially what I did but without the oscillating tool. I quadruple folded a piece of grey Scotcbrite pad over and old putty knife (with rounded corners) and worked it between the fins. I did this dry with no lubricant. I might go at it again in the winter time. Maybe do the same for the Titan too.I recently saw a cool method for cleaning engine fins. It involved an oscillating tool with the cutting teeth ground down and a piece of scotch bright pad folded over. Add a touch of penetrating fluid and makes quick work of it.
I've also employed a gun cleaning kit with a .22 barrel bore brush and some degreaser, brake cleaner or pentrating fluid.
