Yeah... find a 16 yr old neighbor kid and pay him to kick for you.Any suggestions what I might try next?
Or tie a tow rope to the forks and get my wife to pull me down the street.Yeah... find a 16 yr old neighbor kid and pay him to kick for you.![]()
I thought you wanted to start the bike????Or tie a tow rope to the forks and get my wife to pull me down the street.
Can you get a pic of that?While looking for tdc I saw the exhaust valve that looked a bit odd.
Well I squirted a bit of gas in the spark plug hole and kicked it over half a dozen times then I heard a faint fart. Encouraged I kicked it again and it started.Check the decompression parts/system and make sure it's adjusted correctly. If it's not, you could be losing compression there.
Iirc, it holds the exhaust valve open to kill compression.
In my experience (and this is of course a generalization), if you do not get much improvement transitioning from dry to wet, it is more likely a valve issue than rings-sealing....dry I’m getting around 55+ psi and wet with oil a bit over 60. Tells me the bore is buggered or I have valve issues.
I’m not putting too much faith in the compression test results. The numbers are scary low yet riding it around the block it pulls real hard. I haven’t tested it since I got it started. Maybe sticky rings or valves have loosened up? I’m getting fresh fuel this afternoon. If it starts up and runs well I’ll do another compression test.In my experience (and this is of course a generalization), if you do not get much improvement transitioning from dry to wet, it is more likely a valve issue than rings-sealing.
In my experience, if it really only had 55 to 60 psi compression, it would run very poorly, if at all. My sense is that if the engine hasn't run in a long time, the valve seats need a "run-in" to clear debris and re-seat themselves and the rings also need some movement to free themselves up. An overnight soak with a penetrating oil may help that.I’m not putting too much faith in the compression test results. The numbers are scary low yet riding it around the block it pulls real hard. I haven’t tested it since I got it started. Maybe sticky rings or valves have loosened up? I’m getting fresh fuel this afternoon. If it starts up and runs well I’ll do another compression test.
Agreed. I went to start it today with fresh fuel. First kick and it burped but didn’t start. I kicked and kicked until my leg and back said no more. Pulled tge plug and it was wet. I dried it off with a torch , spun the motor several times with the plug out to clear excess fuel. Back together, kick, cough and nothing more. I figured out a couple of things (most of you probably already know this). When I kick it and it doesn’t start, if I bring it to TDC and kick again it won’t even fart. Roll it another 360 degrees and I’ll almost always get a puff out of the exhaust. The general instructions to start these tells you don’t touch the throttle unless you want to flood it and get a good kick back. Although the plug was getting wet I had a notion the idle was set too low for it to fire with the slide so low. I adjusted up the idle screw a bit and kaboom - it started. @Bob Wegman ] mentioned a fast idle button on the idle screw. I found this and cleaned it so it would move. This helped tough starting too. My kicking technique is improving too.. I’ll test all my theories tomorrow with a cold start. Fingers crossed it will go.In my experience, if it really only had 55 to 60 psi compression, it would run very poorly, if at all. My sense is that if the engine hasn't run in a long time, the valve seats need a "run-in" to clear debris and re-seat themselves and the rings also need some movement to free themselves up. An overnight soak with a penetrating oil may help that.
That doesn't sound unhealthy at all! Steady idle, responsive to to throttle snaps, no smoke at all from the pipe and you've reported that it pulls hard. Sounds like a good runner to me!
All I could ride it was up and down our driveway and across the street - maybe 100ft. Pulls hard, felt like the front wheel was about to lift off the ground if I had more space and rear brakes! I agree, I think the motor will be ok. Just need to get the starting process perfected.That doesn't sound unhealthy at all! Steady idle, responsive to to throttle snaps, no smoke at all from the pipe and you've reported that it pulls hard. Sounds like a good runner to me!
