Winter project #2
I’ve read about it in the past. I think wintergreen oil as well. Iirc the lady time I looked for wintergreen oil it was crazy expensive.
I stand corrected...it is wintergreen oil and if I recall correctly, it is not really all that expensive... $15 buys you 120 ml and $50 buys you a liter. You don't need any more than the 120 ml. It works!
Tell us more
Buy it from Amazon. In terms of the use of the wintergreen oil? I used it to restore all of the rubber bits on a barn-find XS650 D. You simply submerge the rubber for a couple of days and it comes out pliable and smelling minty-fresh! It will not restore completely fossilized rubber, but does a pretty good job on stuff that just become stiff and brittle with age.
And you leave a fresh pleasant scent wherever you ride
I haven’t tried starting the SR since it fell on me last week. A friend dropped by and I asked him to try to start it. No go, not even a poof. I dare not try it myself with my still painful hip. I don’t know what tge solution will be - maybe a Mikuni round slide carb. Many have told me if the carb isn’t 100% it will be a bugger to start. We’ll see.
It's odd that the SR500/XT500/TT500 have a reputation of being hard to start, at least from what I hear/read. My XT350 on the other hand, always starts promptly and is also kick-only. Now, mind you, it is a different engine with a different carb, but still a four-stroke single. Practice makes perfect?
Well I’m a bit bummed out. I bought the SR500 knowing it had newish Avon Road Rider tires. I planned to transplant them onto the Titan. I removed the front tire and replaced it with Metzeler Block C tire. Nice vintage looking tread. I ordered a matching rear tire. The tire I ordered was a stock 4.00-18. I was looking at the back of the SR500 today and thought the tire looked a lot bigger than the new one. I checked and sure enough it is a 120/90-18. Too fat for the SR and Titan 2.15” stock wheels. I guess I’ll mount the new Metzeler on the SR anyway and try to buy an Avon in the correct size for the Titan. Last time I looked they were out of stock until the end of the year. I’ll try to sell the Avon to recoup some $. It’s like new.
I had a couple of friends over today and we tried to start the bike. No go. Tried some ether, still no luck. Checked spark again and it seemed to be erratic. We tried new plugs, much the same. We pulled the plug cap off and tested spark from the coil lead to ground and got a strong spark. Suspecting a bad plug cap we tried several, including a new one (all 5K resistor caps) and couldn’t get a consistent strong spark at the plug. New caps, new plugs, no difference. I’m now suspecting I have an ignition problem that’s causing my hard / no start condition.. I’ll have to check it out further when I have time. Odd thing is, strong spark directly from the high tension lead but not at the plug. I wanted to try a non resistor cap but couldn’t find one in my stash. I did remove the cap from the Titan, which runs well, but didn’t improve the condition on the SR. Could the spark be weak enough that it’s being suppressed by the resistor cap?
Apparently the SR has two circuits that feed power to the coil. One for starting and one for running. My research tells me it’s not an uncommon failure for the starting circuit to go bad. I hope it’s not that because the replacement parts are unaffordable (for me on this project).
Time will tell.. stay tuned.
Memory is very very fuzzy, but I recall reading about a guy that used a Suzuki GN250 (Gonzo) box to replace his factory igniter box on either an SR400 or 500, don't recall which. Might be something to look in to?
I can research that Jim. Strapped to a chair I accessed the wiring harness and took readings of all of the aforementioned circuits. I retested the coil too. All were well within spec. The no fire is puzzling. My back is done for the day so I’ll push the bike back into the garage until next week.
When I get back into it I’ll do a borescope check and leak down too.
I’ll figure it out eventually.
