It's the secondary. It sends a spark out on the HT lead. On ANY electrical system, we need a complete circuit for electrons to navigate. On a dual output coil (think TCI, Boyer, Pamco, etc), the ground path runs across to the other plug and back through the other HT lead, back to the secondary. So it's what we call a "floating ground." On a single output coil such as yours, there's no second HT lead and plug to complete the path (circuit), so the secondary coil needs a return path... that's the internal ground.
The primary is grounded because in a CDI system, a capacitor shoots all it's energy all at once. So it doesn't rely on points to complete the circuit (the trigger, if you will). It needs a ground of it's own. Hence the internal grounding.
