Winter project #2
You get into a relationship with a bike like the SR. I seem to remember, and it was a long time ago, that instead of using the white button for a 'not cold' start I just used to give a tiny smidgen of throttle? Again, memory is only approximate, I recall the SR being a first kick start pretty much every time?
At least you're now happy you can always get it running.
Out for more test starting today. I think one important part of a successful start is the kick start lever position. If it’s at 10-11:00 that gives a good spin of the motor which should translate to a higher probability of starting. If you try staring at 9:00 there’s less crank speed. If I find TDC and the kick starter is engaging at st 9:00 or less I’ll often spin the motor to TDC again to get max crank speed for starting.
That's it! You're starting to get the feel for it. It's familiarity, you get engine, kick lever, throttle in familiar positions, then key ON, one kick and hopefully . . .
My cold start was not 100% successful today. 1st kick, one stumble and didn’t want to fire again with or without choke. Decompress, three kicks with lever pulled, next kick running. I’m starting to think maybe that’s the regular procedure. Perhaps two kicks will do. Trick is to quickly get it onto choke before it coughs and dies. More tests this afternoon.
I feel I’m closer to the right, repeatable combo.
IMHO easier to push a button. lol.
Owning this bike is frustrating. Just when I think I’ve got a starting procedure nailed down, I try it and the bike doesn’t start. As mentioned before I always seem to be able to get it running, it’s just not the same process each time.
I was told the header pipe on these bikes was double walled. There’s three holes in the outer pipe to vent expanding, hot air. The inner pipe apparently fails quite frequently making the header a single wall pipe. That said, then exhaust gases will try to escape out of the three holes in the outer pipe. On my bike, the p.o. has welded shut the two upper holes but left the bottom one open. When the bike is running you can feel hot air pulsing out of the hole. You can hear it a bit too. I was concerned this hole might have it fail inspection so I think I’ll weld it up this winter. The other option is to cover the hole with a SS band clamp.
It’s turning out that this bike has no shortage of things to fix. That’s ok since I bought it as a winter project. At some time I need to refocus my attention on the Titan and get that finished.
. . . Trick is to quickly get it onto choke before it coughs and dies . . . IMHO easier to push a button . . .
Can't you catch it with the throttle? You might be over-thinking it a bit - just remember that 95 lbs Japanese girl.
It's a light and simple bike and Mama Yama decided a starter added unnecessary weight and complexity.
Yes you’re correct it should start easily. There’s a possibility that although it runs well when started, there could be underlying engine condition issues eg compression.
I tried to catch it with the throttle but it usually coughs and dies.
Pretty soon I’ll start disassembly and worry about ease of starting next spring. I may do a leak down test before tear down.
Did everyone see the funky gear train driving the tachometer? At the end of the second video. Looks cool!
I took my SR off the road this season ( in the spring time) because it all of a sudden after 45 years just refused to start one day. It had lost a lot of compression. The exhaust valve was leaking, which I found on a leak down test. I freshened up the top end with a valve reseating, new rings and new valve seals. Now the SR is running fine and I will do some much needed sprucing up for next year. Hang in there, you will get it sorted. They really are a fun bike to ride. If you think it isn't worth the trouble, you can sell it to me , and when you realize, selling it was a mistake, I will sell it back to you for the same price. So, there.:)
Now there’s an offer that’s hard to refuse!
The weathers a bit cooler today and the bike decided to be quite a bit more ignorant to start. Multiple licks, with and without choke, clearing the combustion chamber with kicks and the battle went on. Started every time I tried but never easy. Odd thing is if it does start momentarily but I’m not quick enough to catch it, immediate follow up kicks will never start it. It’s also dripping something on the exhaust - I’m thinking maybe brake fluid from the master cylinder as it smokes once started and the exhaust is hot. Further investigation needed.
Today when idling a bit it had a couple of dreaded coughs but never died. A bit of choke for a moment and it appeared to go away.
When I tear it apart this winter I’m going to clean the carb myself and check jet sizes. When I got it and opened it up it was clean so I trusted all was in order. I’ll double check.
I think this is supposed to be fun. lol.
Bob did you use OEM rings and valve stem seals or aftermarket? What did you use for the cylinder base and head gaskets?
I used OEM rings, valve seals and base gasket. I had the base gasket and rings in my parts stash. The head gasket I bought on the internet is all copper. I went that route because I always had good results with copper gaskets in Triumphs and Nortons.
How difficult is it to pull the motor? Must be lighter than an XS?
