Torin215
Hey is there anybody out there in the Philly bucks county area good with wiring up the pma and ignition. I have tried everything and have failed. It’s an 81 and the parts are from mikes xs. Willing to pay.
This bike is a total rebuild into a hardtail. I have tried every diagram I could find I have power to everything but no spark.What is the specific problem you're experiencing? Mikes XS Charge PMA should be pretty straight forward.
I think the main problem is the ignition system the electronic advancer dual output coil.This bike is a total rebuild into a hardtail. I have tried every diagram I could find I have power to everything but no spark.
Do you have a fully charged battery? Have you made sure your grounds aren’t covered in paint and getting good bare metal contact?I think the main problem is the ignition system the electronic advancer dual output coil.
What kind of ignition do you have? Are you using the Mikes XS-Charge ignition as well as the PMAI have power to everything but no spark.
YesWhat kind of ignition do you have? Are you using the Mikes XS-Charge ignition as well as the PMA
