Is it a gas turbine?!!
methinks this should be in the
The staggering idiocy of some folks in the on-line marketplaces never ceases to amaze me. I use FB to dispose of stuff that I no longer want or need quite frequently, like many others. I have met some great buyers and others that must have been last in line when brain cells were being handed out!Just your buddy gggGary here. A WTF story not picture, sorry, not sorry. I sold a set of Suzuki SV650 carbs on fleabane, and hilarity ensued. Before purchasing he questioned if all the jets were in place and I confirmed they were.
Conversation between me and the buyer of the carbs. Go to the end and read up, bottom to top.
6:57 PM
Profile Image
No I haven't I believe i will just take them complete apart and rebuilt all the way. As I have the kit. I'm this far on them may as well make a day of it. Just got done with 2015 Ford fusion 2.5 timing job the other day . No key way on crank sprocket or cam phasers relies on torque force and diamond washer. Harmonic balancer could be hit by say a brick and cause it to jump time is insane
6:53 PM
Cool! jus' trying to help. While digging I noticed that these carbs have a fuel filter buried under the float valve seat. Have you opened cleaned those screens? a different yootoob vid showed that issue on an SV650 that was running lean, popping.
6:38 PM
Profile Image
I took the bowl off and it's capped so you are correct.
6:32 PM
Profile Image
2
6:31 PM
Profile Image
1
6:31 PM
Profile Image
I apologize you are correct. It is confusing that suzuki them selves show a airfield screw with the screw itself obviously then spring normal but the a small washer and rubber o ring
6:31 PM
2 photos
I'm pretty sure those holes are for a pollution control system used on California bikes. Possibly the purge port Pic is from a vid that has a line connector in that hole, why I wanted you to see if that small hole at the bottom of the threaded hole goes anywhere or if it's just a dead end on a 49 state bike.
6:07 PM
Profile Image
Again no worries have a good weekend yourself
5:08 PM
Profile Image
1
5:06 PM
Profile Image
There is a hole if you look close
5:05 PM
Profile Image
I already said I'll take the hit no worries it's change in a bucket no worries
5:05 PM
Would be interested to hear the final resolution on this.
5:04 PM
Profile Image
No need to respond i need nothing else from you. Have a nice day
5:03 PM
These carbs came off a complete bike I parted out (years ago) As i recall it was complete nothing removed I kept the carbs all as a unit. I just am not sure what those threaded holes go to. I don't THINK they are to do with the pilots. Not trying to be sarcastic, cough, just helpful. I suppose I should have investigated more wehn they were still here cuz I was kinda thinking you weren't really getting what you wanted. Were does carb cleaner go if you spray it in those holes? Have a great weekend.
5:03 PM
Profile Image
2
5:02 PM
Profile Image
1
5:02 PM
Profile Image
2
4:56 PM
Profile Image
1
4:55 PM
Profile Image
Oh look what Google lens has to say.
4:55 PM
Profile Image
It's for air fuel control at idle as it plainly states. Ones engine is warm it will not run correctly that is a matter of fact not opinion.
4:54 PM
Profile Image
2
4:51 PM
Profile Image
Too the right you don't see the threaded hole with the hole at the end of the port.
4:51 PM
Profile Image
1
4:50 PM
Nov 6, 2026
Profile Image
Ok the sarcasm is completely unnecessary. I also know a thing or two. But your not looking at the correct area
4:50 PM
Profile Image
1
4:43 PM
18, 19, 29 and 21.....21 AWell color me crazy but that's the idle fuel screws, that are in place on the set I sent you minus the block off caps which were only there to keep our dirty little fingers from adjusting the screws. Not needed at all for operation. I mean I know a little about carbs.... You will need to work on the butterflies/throttle shafts on that set, they are stiff. Hope it all works out for you.
3:05 PM
Profile Image
18, 19, 29 and 21.....21 A would be the brass cap I was referring to. No worries tho. I have a rebuild kit minus those I'll rebuild the ones I got from you as they look to be in better shape. For those screw assemblies there calling it is 43.00 dollars which in my opinion is crazy. But cant find aftermarket anywhere.
2:52 PM
Profile Image
2
2:49 PM
Profile Image
1
2:49 PM
Profile Image
Yes suzuki refers to it as adjuster which is crazy. Part number 13279-19F10 which isn't actually pilot screw per say. But it does control fuel and air ratio at idle. Not to be confused with the idle cable. It's originally capped off with a brass insert.
2:47 PM
you sure something belongs there? The pilot jet #23 should be in the carb body right next to the main jet. And it's in stock at partzilla SUZUKI OEM PILOT JET | 09492-15017Part #: 09492-15017
2:43 PM
(gg; this is the hole in question...)
To the right was what I was looking for pilot jets
1:38 PM
Profile Image
1
1:38 PM
Nov 6, 2026
Profile Image
I'll take the hit but these didn't have the screws either
1:37 PM
Profile Image
Ok great thank you
7:46 PM
I changed shipping to ebay's USPS ground it will go out tomorrow.
7:33 PM
UPS 1ZXG9979YW76472639
7:14 PM
Profile Image
Oh by the way I like the two party cancel sign. I have been previous to things for 30 years. Neither here nor there be prepared my friend things are about to get crazy no doubt
7:12 PM
Profile Image
And seller of good status
7:10 PM
Profile Image
I will lock you in as a buyer
7:10 PM
Profile Image
1
7:10 PM
Profile Image
It's payed my friend PayPal is linked
7:07 PM
I accepted your offer, now you pay for it and I ship.
7:06 PM
Profile Image
Ok great thank you
7:05 PM
You accepted an offer
$110.00
7:01 PM
Profile Image
What do we do next
6:59 PM
Profile Image
roger9891 sent an offer
$110.00
6:53 PM
Profile Image
Ok
6:53 PM
shipping is $23 make an offer of $110 and I'll accept it.
6:51 PM
Profile Image
Can't find them anywhere for 1999 to 2001
6:48 PM
Oct 30, 2026
Profile Image
Wyoming
6:46 PM
Profile Image
82716
6:46 PM
Profile Image
Again I am simply buying them for pilot jets as mine are missing. My carburetors are fine just after warm up acts crazy. I bought the bike got it running and it would die after warm up took carbs off and noticed idle jets. Pilot screws was missing
6:45 PM
whats your zip?
6:42 PM
Profile Image
Ok what about 100.00 you cover shipping
6:41 PM
OK
5:48 PM
Profile Image
Ok let me do some checking i may be back in touch thank you for your time
5:47 PM
no, sorry
5:45 PM
Profile Image
Oh they are there. Would you take 75.00
5:44 PM
2 photos
12
What a load of nonsence (We call them Twat in the trade).Just your buddy gggGary here. A WTF story not picture, sorry, not sorry. I sold a set of Suzuki SV650 carbs on fleabane, and hilarity ensued. Before purchasing he questioned if all the jets were in place and I confirmed they were.
6:57 PM
Profile Image
6:53 PM
6:38 PM
Profile Image
6:32 PM
Profile Image
2
6:31 PM
Profile Image
1
6:31 PM
Profile Image
6:31 PM
2 photos
6:07 PM
Profile Image
5:08 PM
Profile Image
1
5:06 PM
Profile Image
5:05 PM
Profile Image
5:05 PM
5:04 PM
Profile Image
5:03 PM
5:03 PM
Profile Image
2
5:02 PM
Profile Image
1
5:02 PM
Profile Image
2
4:56 PM
Profile Image
1
4:55 PM
Profile Image
4:55 PM
Profile Image
4:54 PM
Profile Image
2
4:51 PM
Profile Image
4:51 PM
Profile Image
1
4:50 PM
Nov 6, 2026
Profile Image
4:50 PM
Profile Image
1
4:43 PM
3:05 PM
Profile Image
2:52 PM
Profile Image
2
2:49 PM
Profile Image
1
2:49 PM
Profile Image
2:47 PM
2:43 PM
1:38 PM
Profile Image
1
1:38 PM
Nov 6, 2026
Profile Image
1:37 PM
Profile Image
Ok great thank you
7:46 PM
7:33 PM
7:14 PM
Profile Image
7:12 PM
Profile Image
7:10 PM
Profile Image
7:10 PM
Profile Image
1
7:10 PM
Profile Image
7:07 PM
7:06 PM
Profile Image
Ok great thank you
7:05 PM
$110.00
7:01 PM
Profile Image
What do we do next
6:59 PM
Profile Image
$110.00
6:53 PM
Profile Image
Ok
6:53 PM
6:51 PM
Profile Image
6:48 PM
Oct 30, 2026
Profile Image
Wyoming
6:46 PM
Profile Image
82716
6:46 PM
Profile Image
6:45 PM
whats your zip?
6:42 PM
Profile Image
6:41 PM
OK
5:48 PM
Profile Image
5:47 PM
no, sorry
5:45 PM
Profile Image
5:44 PM
2 photos
12
IT's spreading, though. Some of those 12 and 14mm will be getting ideas next.Pulling out of the drive this morning and saw something that glittered in the headlamps, got out and found this, OF COURSE it's NOT a 10MM
