Okay, first of all, I’m not trying to stir the pot here. I’m just looking for some advise.
I purchased two Keyster carburetor rebuild kits from Mike’s XS. I followed the instruction and ordered two different kits (one for the left carb, one for the right). I received the kits and although they had different parts #’s and and the instructions indicated one was for the right carb and the other was for the left, there didn’t appear to be any differences in the kits. Also, they both contained parts for the ‘plunger’ style choke. The type with a pull knob vs. the type with a lever. But having read that many rebuild kits contain parts for various carbs and that some may not be applicable, I figured that must be the case here.
However, the choke gaskets were close for one carb but didn’t quite line up right. And was totally off for the second carb (the one on the right that doesn’t have a lever. Both kits basically contained the gasket for the left carb.
After reaching out to Mike’s and providing the requested pictures showing the problem, I received a reply email saying they “could see the problem. Your carbs are off an XS 2”.
But if that’s the case, then why doesn’t my carbs set have the plunger style choke knob? Also, like I said, the gasket for the choke is very close for the left carb. It just doesn’t line up perfectly at some of the screw holes and ports. I’m thinking I ordered the right kits, these are just poorly made & assembled kits.
Anyone have any suggestions or insights on this? If it’s just that the Keyster kits are not very good, any suggestions where I could source these parts?
Thanks all for your input!
