XS 650 big bore 750
Smudge2024
ct
I picked up a 650 that has been bored to 750, 10:1 compression, ported head, mikes xs cam. I am putting mukuni 36mm flat slides carbs on it. Looking for a starting point on jetting if anyone is running a similar set up.
Thx Mike
Which mikuni flatslides? The linked style with accelerator pump, or the non-linked direct pull style? I have the linked RS style carbs(for whatever reason the 34mm is still called a TM). They come "pre jetted" and other than going down on the pilot and moving the needle I didn't change much. These are also referred to as the topham carbs, as topham in germany was the only place selling them for a long time.
My engine is 700cc, xs1 cam, rephase, thinner gaskets, pretty open exhaust.
View attachment 343036TM no pump, I bought these pre jetted for my xr 750, ended up staying with the 38s. so im using these on the yame 750. I run these both for hillclimbing so I on-off throttle response to be crisp. I'm just going to try them they way they are, Bikes are similar in cc's. I may just weld in some bungs and dyno tune it.
I like your bike! Nice fabrication and attention to detail
