XS Metisse
I`ve been following this one! Beautiful.:thumbsup: Love the heat guard with the dimple holes.:heart: Have you checked the drive chain for clearance yet? I notice the motor sits a lot lower in the Metisse frame which should give more clearance on the bottom side. What is the ratio?
The wheels are off an XT500, so I was limited with the size of the rear sprocket. I’ve fitted a 17T gearbox and 46T rear.There are no clearance issues, but I’m going to fit a plastic wear strip on the swingarm pivot point to protect the tube.
You might be better off with a 18 tooth front sprocket would help with clearance and the gearing, with the gearing you've got you'll be topping out at about 50
Hi Jay,
I tried that.
Running at 18T front sprocket involves removing the inner chain guard and limits you to running normal chain because HD & sealed chains don't fit.
Finally finished my build,
it’s been a really enjoyable build. Many thanks to Ant Beynon of Pipes And Stuff for building the exhaust system for me. The heat shield may have to be modified depending how hot my leg gets.
XS Metisse number 2 build underway, a good friend of mine liked my build so much he’s asked me to build one for him, frame is ordered, Triumph Hurricane forks and 2LS front brake bought and ready to fit. This one will be slightly different as he wants all of the tank,bodywork,mudguards etc in polished alloy, if I think it’s better than mine I’ll keep it and he can have mine.
And so it begins again, I’m now building another XS based Metisse, I picked up the frame yesterday from Rickman Motorcycles. The engine is freshly rebuilt, I’m using Triumph conical hubs front and back with Triumph Hurricane forks. All the bodywork is all Gloss Black.My aim is to get into the 2023 calendar.
Fantastic build! I'm starting an X650 build of my own what rubber mounts did you use for the tank and seat pan? Also what fasteners did you use for connecting the rear mudguard and seat pan as they look nice and tidy? Will take any reccomendations or lessons learned along the way?
