I hooked up a temporary fuel tank to my XS2 project, preparing for an initial startup of a bike that's been sitting for who knows how long. I am completely unfamiliar with these carburetors, so I'm looking for a little info. As soon as I open the petcock, fuel runs out of a tube on each carburetor, which I assume is the overflow tube. I assume that either the valve in the carbs are stuck open, or the floats are stuck in a lower position, or the valve seats have some crap in them keeping the valve from seating. I tried shaking the bike a little, and some light tapping on the bowls with a light hammer. Neither of these changed anything. I guess I need to pull the carbs and clean and inspect. Is there anything else I should try short of removing them?
there are no shortcuts to a good working carb. Junked up float valves, and leaky, cracked floats common on the BS38s. Odds are your throttle shaft seals are toast also
