1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
Xs650 1983 headlight problem
Discussion in 'The Garage' started by Caferacer650, Apr 18, 2021.
  1. Caferacer650
    Caferacer650 XS650 Member
    11
    6
    3
    Canada
    I have an xs 1983 and the headlight and speedo light no longer work. Everything else works....
  2. nj1639
    nj1639 Paleo-simplistic Top Contributor
    Reply #1....... Hey! Welcome aboard. Tell us a bit about you and your bike, doesn't have to be too detailed but a little sumpin'.
    Reply #2........Bulbs burn out.
    Reply #3........Welcome aboard! Sometimes the bulbs do burn out and have to be replaced. Not sure of your experience or how long you've had the bike but to access the speedo bulb you'll have to lift the speedo out of its chrome bucket, access from below.
    The headlamp comes on when you tickle the ignition by either starting the bike or attempting to start the bike.....one of those newer model improvements there that most could do without. If the lamp doesn't come on it could be the bulb too, I would check with a known good headlamp or ohm between the three plug ins......I forget how that reads but would compare it to a known good lamp.......buy a spare. They don't cost anything to feed them once purchased.
    lakeview likes this.
  3. Caferacer650
    11
    6
    3
    Canada
    3 years old I have this bike the new speedo sound with diode to install for the signal of the flashing,swich side clutch new all the bulbs have been tested and works but I am not running with yellow wire
  4. nj1639
    Aye, a bit of custom accessories.
    The yellow wire may need to be hooked up. Thinking I disconnected mine on my old '83 when I was bypassing some of the safety features and I lost the headlight, hooked it back up and all was well.
    You might want to look in to simplifying your wiring. Look in the Tech tab under "Electrical" for some schematics. If you're going to get in to custom electrical fabrication you'll be the expert of your bike.
    Good luck!
  5. Caferacer650
    11
    6
    3
    Canada
    I jumped to positive battery to the blue/yellow rld wire and it works so my wired is good
    nj1639, jetmechmarty and gggGary like this.
  6. XSLeo
    The yellow wire from the alternator feeds power to the safety/headlight relay. Once the alternator makes about 4.5 volts on the yellow wire it trips the relay. This sends power to the headlight.
    If you are building your own wiring, inthe electrical section under Some Wiriing Diagrams look for #4. I like this diagram. It shows the basic points version with squares with the later TCI and Combo reg/rec. The E-Start with the safety relay is in the upper right corner.
    With a few minor mods this diagram works for most any combo of parts you can come up with.
    nj1639 likes this.
Share This Page
