I rode the bike today and the rear brake feels pretty good. Harder to lock up, good thing. The changed/adjusted leverage ratios are pretty good for WAG engineering.
The bike had a varying "rumble/vibration" that I could not pin down to Road speed or RPM. Gone entirely with a new chain.Strong yes vote from me.
Stiff links are full of rust (sand paper), as you ride those links are tearing themselves apart internally.
Here's a sad tale from Weekend rider
https://www.xs650.com/threads/broken-chain-mystery.47304/
I visited my machinist today to cut new mounts that will move pegs forward 2" and down 2" from your pictures. I have a very low seat height. What I jave is nice but might e "tight" after 1/2 hourI mounted mine direct to the frame after some mods to lower the pegs.:
Can you effectively operate the brake with the lever that short.Backsets 2.0. New brackets are drilled and the fiddling with install is more oops. The new location gives good brak pedal position but the shift linkage has interference issues with the frame mount studs. One option is putting the link below the peg though that leaves it exposed. I will try shimming some clearance.View attachment 333117View attachment 333118
For God and everybody to see. Hi res, zoom in and laugh... Thisis an adventure bike... Adventure in crappy weldiing...Why are you hiding your weld behind that shift lever? Lol
Ugly but effective... Give me the business all day long! I deserve it. You should see the welds chronicled in the "Red Bike" build thread... https://www.xs650.com/threads/its-time-to-start-a-winter-project-the-red-bike.62447/page-161 of a kind Kevin !
Kinda like a an old barmaid sturdy but nice to look at
I was going to say nice to look at thru the bottom of a beer mug but that would be givin you the business
I'll respectfully disagree. Don't get me wrong, I wouldn't get caught dead with one, but you can do passable-ish welds with flux core. If it pops and sputters, reverse the polarity. Most all of 'em have wire lugs and instructions inside the cover on how to swap it. Give it a shot...My Highschool Metal Shop teacher friend said "You can't make a pretty weld with flux core wire" so I got that...
Tje leads are swapped, I am still on the learning curve with this little welder. I did a ton with gas shielded wire 1994-2008 so I do have the feel. This is a wimpy little 120 ac unit. I have to move MUCH slower, and I am getting accustomed to that and getting better.I'll respectfully disagree. Don't get me wrong, I wouldn't get caught dead with one, but you can do passable-ish welds with flux core. If it pops and sputters, reverse the polarity. Most all of 'em have wire lugs and instructions inside the cover on how to swap it. Give it a shot...
YOU will need to ride this bike in two weeks. Even if it is just a 5 minute up and down the local road test drive. 750cc is impressive.It holds the bike up when it needs to
Tucks under when it's supposed to
And it's painted black
What's not to like
