xs750 build step by tedious step, "build-along" with me
billy icon
test pilot,gunnie pig, and all around experiment
mt hood OR
ok Kids, I've been collecting parts for some time now to do this build ,I'm not sure where they all came from as time has passed, and I would like to build this together, today I'm just sharing what's collected so far but here is a list of components I'm going to attempt to use
447 bottom end, case and everything never taken apart (year to be identified soon)
xs1 cylinder prepped for 80mm pistons, (bridge removed in between bores to use 447 chain guides)
slightly ported 447 head (valve springs to be determined I have xs1 and 447 springs)
xs1 camshaft with 447 cam gear allready swapped onto it (cam timing to be redone during build)
new DID cam chain
750 pistons ( manufacturer unknown help me out here)
rk rings
athena full gasket set with 81mm head gasket
two more head gaskets one 0.38mm fiber and one 0.45mm multi layered steel.. 3 diferent to chose
complete seal kit
boyer mini electronic advance setup with coil
two new 32mm roundy slideys
new ebc clutch kit with new EBC springs
