I'm taking my time and studying the wiring diagrams while trying to bring one piece to working order at a time. I'm STARTING with my STARTER. Lol.
I can jump the solenoid to engage the starter, but no matter what I do my start button doesn't activate the starter. If I can bridge the solenoid and it does the thing... It's probably not the problem... Right?
By the looks of the diagram, theoretically I can put either lead on either post. Because all it's doing is moving 12v from battery side to the starter side. Correct me if I'm wrong on that.
The button being pressed is not powered, but rather supplying ground for the coil in the solenoid to close the gap and power the starter..?
When I continuity tested the blue/white wire to ground it beeps.
The red/white wire is plugged in, and is used for the Killswitch. It ALSO makes my meter beep at me when I test continuity to ground... Shouldn't that only beep when the switch is in the off position?
I'm really having a hard time with it because of the wiring harness being an aftermarket one. There are certain plugs that a 78 would have that a 76 doesn't. But most of it is easily cross referenced. I have diagrams for both models. I'm just having a hard time diagnosing why my starter won't turn when I press the button.
Starter is ground by being mounted to the engine yes?
Solenoid is ground by being mounted to the battery box...?
I'm probably doing something wrong. As usual. But here we are.
