Far as I know, Greg, you can't install those adjuster with the engine in situ. You have to pull the rocker box to get 'em out.
I appreciate the reassurance. It leads me perfectly into the next small bug I can't crack on my own. You're mentioning the advance bringing on higher idle... I can notice a slow but steady rise in RPM when the bike is just idling... If I start the bike and set my idle to 1100 then in about 5 minutes or so I'm right up to around 1500rpms. Turning down my idle screw will temporarily solve the problem, but it doesn't fix it permanently because then on a cold start my idle is so low that the bike wants to shut off.Sounds fine to me. These motors do make some noise, especially if you're using that 40wt. diesel oil instead of the normal 20W-50. I tried the 40wt. but switched back to the 50wt. because of the noise. Your idle speed seems a bit high. 1100-1200 is the norm, get much over that and the ignition can start advancing, and that brings even higher RPMs on.
As far as those elephant foot adjusters go, I don't have a link. It's been a while since we discussed them on the forum here. The screws we use are made for VW Beetles and are a copy of Porsche screws. Do a search and I'm sure you'll find info on them. Just be aware that the head needs to be off to install them because you need to grind some off the rockers for clearance. So, I don't think you'll be installing them any time soon, lol.
Welcome to the world of carburetorsIf I start the bike and set my idle to 1100 then in about 5 minutes or so I'm right up to around 1500rpms. Turning down my idle screw will temporarily solve the problem, but it doesn't fix it permanently because then on a cold start my idle is so low that the bike wants to shut off.
When exactly is it okay to start crying..? Asking for a friend...Welcome to the world of carburetors![]()
It's not hard for me to adjust on the fly, I'm not so much worried about having to adjust it as I am just making sure it's a common characteristic.If you do a search here in the forum, there was a thread from quiet a while ago on making your own knurled knob for the idle screw on the BS38's. Easier to adjust on the fly...
Sorry in advance for making you all listen to more videos of sounds that are impossible to diagnose over the internet... I just like reassurance and second opinions.
I'll once again suggest dropping the pilot jets one size, readjusting the mix screws and see if that helps.As far as tuning goes I'd say I'm right there at the finish line. There are only two possible little hiccups I can think MIGHT be an issue still.
Number one: when the bike is cold and I try to give it gas at idle it wants to sputter at 2-3k rpm's still and MAYBE lightly backfire once or twice when trying to keep it in the 2-3k rev range (runs completely smooth at idle, no choke.) Once it's warmed up it all goes away completely and rides like a dream. My spark plugs are a really nice dull white/gray with toasted brown tips so my fuel mixture is damn close to perfect.
Finally, there is the issue that it will fire off with the choke but will not run on choke AT ALL. Is this due to the warmer weather? Or is there sumthin' not working with my choke circuit..? Other than the small hiccup when cold, and the non running with choke, it's a dream of a runner. Especially now that it's quieted down.
Thanks for always bein' such a positive, uplifting guy, Raymond. I appreciate it.
You're referencing three circuits... I know there's a pilot jet and a main jet. Is the needle jet the slide needle??? I'm a lil fuzzy on that detail. I've known about three circuits in a carb for a while because I knew there was three main sections of change in air velocity and volume (and which circuit was affected.) 0% to 1/4 throttle is usually one, 1/4-1/2 is usually the second circuit, and 1/2 to 100% is the final one... Or something similar to that science... I'm gonna jump down the rabbit hole tonight to try and better understand the overlapping. What you're saying makes sense so far so I'm diggin' the lesson!No need to cut the plug, just look down into it with a good light. You'll be able to see the ring if it's there.
Something you need to keep in mind while jetting carbs is that the 3 circuits overlap the one next to them and changing one affects that overlapped portion of the other. In the case of the midrange (needle setting), it affects both the idle to midrange transition area and the midrange to main transition area ......
Many times the pilot jet size will be fine - until you lean the needle a step. Then that leans the idle to midrange transition area, often creating a flat spot there, and requires a larger pilot jet to "fix" it.
5twins has more experience than me with the BS38's, so I'll bow out on jetting.....it will fire off with the choke but will not run on choke AT ALL.
