...I need to fix them...
Now that you know they're not supposed to be there I highly suggest you fix 'em, otherwise they'll always bug you.They're perfectly identical. I thought they were there from the factory to clear the handlebars/triple tree. Given that they're 100% identical I'm leaving em' alone. But I wondered the same.
They're definitely there. That's what's so strange about this all... The bike has a front end conversion on it... I'm wondering if the tank came off of a different bike in the past...This happens when the steering stops are busted off the frame (neck) or the lower triple tree. Best you check yours to see if they're intact.
It's all in the blue print and all in due time. Trust me. I agree with you haha.I see room for lots more shelves. You can never have too many shelves, lol.
I usually have a toke or two as well. Makes things much more enjoyable...and put on some music. It's not as boring that way.
I seriously regress in my skills, attention and abilities if I partake in that. I reserve that for celebration of my hard work.I usually have a toke or two also. Makes things much more enjoyable...![]()
I use spray cans because I can't afford the set up for a compressor large enough to spray. The store I use fills cans with automotive quality paint on request with thousands of swatches to choose from. They use a paint camera to match the swatch so you get almost exactly what you pick.Amateur here but I have a question. Is there some point where you shoot it gloss black so you can really check the final profile under a harsh light?
Yeah, I am finding that out. However, if I can feel a spot that's OBVIOUS then I do what I can to make it less obvious. I'm at the point now where when I wet the tank with wax remover I really don't see any imperfections. A coat of clear will make me a liar and I know that. I'm aiming for my very best and even if that isn't perfect it's better than the guy that half asses stuff hahaha. I can be both people sometimes. But not when it comes to body work. I set the bar a lil higher there.Truth is, you'll never catch 'em all.... never.
You can also put it in the fridge to extend its life. Just let it warm back up before you use it.Depending on air temp you may get a couple of days out of the clear before it hardens,
