-Xs79-
A gift for my xs. I haven't come out with this modification yet but I will have less weight in the front.
Nice to see you continuing the updates on your bike. Also LOVE seeing the pics of the events you share with us. Looks like a good crowd and a fun time. The view of the valley below in the one picture is breathtaking. Thanks for posting.
Working on the front hub I realized that when I adjust it it stops, I have changed bearings and checked all the parts.
My spacer was 68mm long as was the space from one bearing to another inside the hub.
It should be noted that I have not yet tied the rim because I plan to paint it.
What happens here?
I appreciate any help.
I believe your spoke pattern is wrong at some places
Nearest to the hub.
If you look at 8 o clock 4 spokes crossing
9 o clock the same
but 10 o clock looks different
I have never done a Motorcycle wheel but bicycles ..and if the spokes are not going to the right place the nut can bottom out
since the length sticking out differs
If that picture is the final setting
Perhaps not the answer to your question .
Nearest to the hub.
9 o clock the same
Thanks for watching. Actually I only assembled the spokes to test the length of the spokes, I haven't assembled the wheel yet.
I found this wheel for 30 bucks. Before and now. What does the lacing look like? The second is a 21 rim.
At last he was able to mount a 21 rim on the front, I felt a little insecure but it looks great.
Notice a bit of bouncing on the freeway.
