I’m having trouble finding Z8 needle jets on any site other than XS650 direct. Neither Nichecycles nor jetsrus has them. Anyone got an alternative supplier?
I'm with 5twins... that sounds like a runaway advance. Could be your tach is off a bit and you're actually at 14-1600revs. You have access to a timing light where you're at right now?Idle speed set at 1100 and it idles fine until it gets a touch of throttle then the revs start. I can shut it off and start it right back up and it idles fine. Touch the throttle and away she goes. Timing is spot on. I vacuum synced the carbs before I left on my trip but will do that again in the morning.
