New here!
The wife borrowed the 81' for some riding lessons! Day one so she was staying slow in an undeveloped subdivision. I sat on the curb with my helmet on so I could talk her through it all using the Cardos in our helmets. Spent a few hours working on her clutch control, shes pretty determined and is picking it up quick! It was fun to see her and the XS getting along so well!🤣
Great looking bike and your Mrs just makes it better. Great to have another biker in the fold.
Finally got stuff from partzilla to finish my front fork rebuild on the 81'. They gotpowder coated, new seals all around, lowered 1", damnper valves, and the damnper rods drilled out. With 20wt, the test ride went swimmingly! Big improvement! I really like the stance now, can sit flat footed at stop lights finally!
Thinking about trying to fit some of the tin side covers to this special to clean up the lines, I realize I will probably have to modify them and/or the frame. How did those earlier tin covers mount? I see the two slots on top of most of them, did they just slide over some tabs on the frame with a thumb screw at the bottom?
Tuis is an '81 Special. I removed the old mount and fabbed up some new ones from .060" mild steel. The bottom mount is a bullet that snaps into the rubber grommet.
l
Yeah, I got a pair of tin covers for my 79 Spec and they just fitted straight on. No mods necessary, iirc. It was a few years ago. Luckily, my seat isn't as weirdly shaped as the Special from the following model, so the room was just about right for the rectangular metal tins.
I do not want to derail your thread and apologies ahead if you are slighted. Seems the Special frame drops the seat base/ fender hoop section of the frame downwards. That means shorter "inseam" folks get a little bit more comfort and security. In my build I added 12.5" shocks to that lower stance which switches the geometry a bit and the sprightly handling is very nice.
I'm under the tank on the '81 today replacing a clutch cable. Long story I'll tell ya guys about soon.... ;) :D. In the meantime though, I'm wondering if you guys would do a head re-torque? It's got roughly 13k known miles, no leaks, just some moist spots here and there that don't really bother me. Do I risk possibly buggering a stud? Or leave it alone? IF I attempt, is it ok to remove one nut entirely at a time to apply some anti-seize? Thanks in advance!
That's the way I'd play it... one nut at a time. I would follow the torque sequence though, jus' cause that's a good habit.
The Yamaha manual calls for 30W motor oil on the studs. That's all I use for anti-seize.
I also wouldn't go all the way out to the book numbers for torque. You can look in Tech for my top end buildup, but I think I decided on about 5 ft lbs less than recommended, for the reasons stated in that thread.
Thanks Jim! I'll re-read that thread!
PS while waking Ole Paint a leak on the case back of the cylinder was just the o-ring on the cam chain tensioner cap, THAT was easy! needed to set the chain anyways. it was kinda loose. 1mm in out while cranking/idling done. Was going to just crank it to set, but it starts and idles so quickly I did it idling.
PS don't forget that 6mm over the cam tensioner :twocents:don't use a torque wrench on t hat one, just snug it with a 10mm on a short 1/4 ratchet and bunch of wobble extensions. That one little bolt is expected to keep about 4" of head gasket leak free.
Oh, excellent advice! I was just looking at that one wondering about what extensions to use🤣
