Yes, these bikes are tough on plates because of the vibration. I make a backing plate from 1/8" thick aluminum plate and 4 bolt the license plate to it with some rubber sheet in between. Haven't had any plate issues since .....
That will work, or maybe even using a marker.I use nyloc nuts but there's another little trick I employ. If you look at the nuts and bolt heads in my pics, you'll see I position them with a point of the hex facing up. That way, I can tell with just a glance if any have moved and/or loosened.
Red torque stripe.I think @jetmechmarty just paints a yellow stripe on all his hasteners so he can do a visual inspection in 17 seconds.
Buzzy is too buzzy.Back to the fuse block. Buzzy died on me this morning while coming to a stop. The problem is the fuse holder has vibrated forward so as to no longer make contact with the fuse and thereby disconnecting the flow of trons. I used super glue to hopefully afix the holder in place.
View attachment 259293View attachment 259294View attachment 259295View attachment 259296
Are you saying the nut is on backwards?First of all, it's on backwards, lol. Use a socket to take it off and flip it around, then it will be easier to access. Then, get yourself a 12mm offset box wrench .....
The not helpful remark is for the backwards nut, not aimed at your advice brother.Yes, the nut is installed backwards. The shoulder on it should face in. That will put the "flats" on the nut out further and make them easier to access .....
Yes, normally the adjuster screw has a Phillips head, yours I'm guessing is an aftermarket replacement screw or whole worm assembly.
And how is this not helpful? If you want to struggle accessing the lock nut then fine, leave it as it is, on backwards, lol. I swear, there's no helping some people. I thought you may have learned your lesson a while back when you threw the chain, but I guess not. You've let it get all rusty and nasty again. This poor old bike, I'm surprised you haven't killed it yet (or it you), lol. I guess this is a good testament to just how well made these old bikes are.
