Clutching at straws? clutch pressure plate bolt replacements
gggGary
If not now, When?
XS650.com Supporter
Baraboo, WI, USA
Was shopping at my "little bro's" place and rounded up a some bitz n pieces,
lengths are a bit off so they're going to need trimming.
I'll do a bit of lathe work and see how it all fitz.
Mikes gets about $8 a bolt these total about $2 each.
And they should LOOK trick installed. Collars and sleeves are stainless, bolts grade 12.9
I'm not very smart, so I'll risk looking stupid, but I don't like it.
The sleeve is a smaller diameter than stock. Fitment issue? Slop?
A little countersunk triangle of metal is resisting the clutch springs, as opposed to a big, fat buttonhead.
And, as said, no one see's it.
But, what do I know? Probably not much...
I do the same, modify original screws .....
The only issue I've encountered so far is sometimes I don't get them drilled straight through. But hopefully that'll be resolved once I finish refurbing this little beauty and can start using it .....
Hey 5T you ever try the old clamp the drill bit in the vice, and chuck the bolt in the spindle trick? That will put in a straight centered hole every time.
