Racerxnico
≈21k miles
Helping a friend with the sale of this motorcycle. He inherited it from his dad (who I understand was the original owner) when he passed away a few years ago. While my friend has maintained the tabs and ridden it a few times since taking possession of it, he isn’t a motorcycle guy and had decided that it is time to let it go.
As near as I can tell it has been garage kept its entire life as there isn’t much of the typical corrosion one would expect to see on a bike of this vintage if it spent any time outside.
While it would start with one kick, it was apparent that it did need a bit of work so over the last month I have:
It isn’t perfect, but I do love that motor. On shake down runs accelerating hard in 3rd gear, it just seems to pull harder and harder (like it wants to pull out from under me). I’m planning on riding it to some local bike nights this month to see what sort of interest it generates.
Located in Seattle and I'd prefer to not ship it, but mostly because I am unfamiliar with doing so and for the right price maybe I could learn . I had a dream last week that someone in Arizona was willing to give me $7k if i would ride it down to deliver
I really don't know how to put a value on this, but giving it my best guess @ $3250 OBO
Pics below are all reduced, but I can send full resolution and anything else you would like to see as well.
Cheers
- Rebuilt the front brakes, both the caliper and master cylinder
- Adjusted the regulator (it was overcharging and cooking the battery)
- New sealed AGM battery
- Checked and adjusted valve clearances
- Retorqued head bolts
- Electric starter wasn’t working so I pulled it to investigate. It bench tested fine so I put it back in and it works. The lower insulator boot was gone and because of the way it was in, I speculate that it may have been shorting back to the frame (friend says it hasn’t worked as long as he could remember). When I reinstalled, I put and new insulator boot on it and flipped wire to give more clearance. Electric start works now.
- The tach was very sluggish so I opened it up and cleaned out old sticky residue, lubed with white lithium, and now it works as it should.
- At some point in its life, someone welded a foot to the kickstand, but it made the stand effectively useless as it was too tall and wouldn’t lean. I removed the foot so it leans on side stand as it should.
- The fork seals were leaking and the dust boots were cracked so I replaced them and gave it fresh 10w fork oil.
Cheers
