I used the XS Performance camshaft in my current engine and will be replacing it with my old Shell #1. I don't recommend the XS Performance cam for several reasons.
1. Valve springs supplied are weaker than they should be.
2. The sprocket can be mounted on its slots for adjustability, but that's not a good
idea. Standard attachment for an adjustable sprocket is three-point mounting with
7 mm. bolts. The XS Performance unit uses two 7 mm. bolts. It can be trusted
if mounted on the holes, but it's questionable otherwise. That means you have to
degree the cam by tweaking deck height if you want to be safe (and there is not,
never was, and never will be any such thing as a "drop in" performance camshaft).
3. The bolts mount in heavy bosses positioned 180* apart. It's one thing to have a bit
of radial imbalance close to the centerline, but the situation worsens the farther
from center the imbalance is placed. Unless you're very, very lucky, the camshaft will
will cause seriously harsh vibration.
