I have that cabinet. Take the stock siphon tube and gun out and throw them in the garbage. Buy this immediately
http://www.tptools.com/p/2320,22_USA-Cabinet-Gun-and-Pickup-Tube-Upgrade-Kit.html That alone will make a huge difference.
The next thing you need is a vibrator motor to shake down the media since the funnel is not steep enough. I bought this:
http://www.tptools.com/Product.aspx?display_id=250 but the motor isn't strong enough so I bought this:
http://www.grainger.com/Grainger/DAYTON-Vibrator-Motor-10C903 It shakes about 5 times as much as the one from TP tools and actually works.
Those two upgrades literally made my blaster work about 5-10 times better than it did out of the box. Their guns really are junk.
You need lots of air! Like 10-15 CFM at the minimum. A 220v 5hp compression will do. I use a 6.5HP gas compressor that pushes 13 CFM and I use a 1/2" air line. I also using high flow couplers and fittings. My 33 gallon Craftsman compressor that puts out 6CFM (or so it says) really doesn't work well at all. Two of them plumbed together on separate electrical circuits might have done the trick.
I have a large desiccant air dryer and after that an air regulator/filter right before the cabinet. You need dry air.
Next you need a vac to clear the dust. A smallish to medium size shop vac will work. Mine runs through a drop trap to catch the big stuff, then a water trap for the small stuff, and then outside. I'm thinking of dumping the water filter since the shop vac was cheap so I'm not too worried about burning it out with the fine dust, and the water trap really takes a lot of suction away from the system. I run RV antifreeze in it to keep it from freezing. So anyway, you need something to clear the dust. That will keep the inside clear and keep media from going out the port in the back.
My cabinet doesn't leak and I didn't seal it at all. People might think their cabinet is leaking when media goes out the port in the back because their vac isn't strong enough. Or maybe theirs really do leak
I use aluminum oxide for everything. I use anti static sprayed on a rag and wiped on the inside of the window to keep it somewhat clear. It needs to be wiped down every now and then.
I bought a foot pedal air valve from ebay (like this one:
http://www.grainger.com/Grainger/INGERSOLLRANDARO-Manual-Valve-2G525). That will be my next upgrade when I get around to installing it. The next step for me is better lighting. Then I might upgrade my window.
Change your tips and air jets when they wear out. It makes a huge difference.
