fishhat
Hey folks,
So here is the first post in what will hopefully be the build thread turning my entirely stock '81 Special into my very own brat. As you can see from my "work space" this is going to be a slow go.
I have to do everything in one parking space in the underground parking garage of my apartment building. Further more, I have to have the project buttoned up every night so that I can park my car. As you can imagine this makes things a little difficult.
Here are some pics of the bike as it stood at the beginning.
The bike is pretty dirty, but it runs....sort of.
Problem # 1 is the charging system. This bike has never charged as far as I can tell. After replacing numerous brushes and the rectifier/regulator, I continued to be frustrated by the erratic voltage that it was putting out. Sometimes it would work, sometimes (mostly) it wouldn't. Along with the charging problem, the bike was idling at around 3500 rpm and backfiring. Having very little faith in my own mechanical abilities, I trusted in my friendly neighborhood classic bike mechanic. $500 (supposedly tune up, carb cleaning/overhaul, electrical system fix, and oil change) later, and I still had a bike that didn't charge, idled at 3500 rpm when the engine got hot, and backfired when I killed it. Rather than continue dealing with that bull shit anymore, I went online and found this wonderful place. I settled in and did some reading. That's when I came up with the plan.
Stage 1: get the bike running properly.
Hughes Handbuilt PMA conversion kit (from Hugh himself)
Pamco ultimate ignition kit (from MikesXS)
Replace all gaskets (stage 1.5)
Stage 2: suspension brakes & controls
Clean up the forks (maybe do Hughe's polishing/shaving service)
clean up front brake (change pads/disc if necessary)
replace master cylinder
clean up rear brake
change bushings in swing arm
Stage 3: framework
brat kit from Visual Impact (anyone know a good frame guy in So Cal? I know nothing of welding)
Seat
New rear fender
Batteryless? (haven't decided on this one yet)
Stage 4: looks
Powdercoat (frame, engine, wheels)
wheels (spokes or powdercoat stock???)
new gas tank (not sure where I want to go with this, might just wander around a motorcycle graveyard for a while)
paint
headlight, speedo, tach
tail light/license plate
That's about it for what I can think of right now. I'm certain that the plans will evolve as things move forward.
To the progress so far....
As I've mentioned in another post ( http://www.xs650.com/forum/showthread.php?t=15092 ) I had some initial problems figuring out the PMA install. As of tomorrow, that problem should be solved.
I tore into the electrical system this weekend. I installed the PMA, and opened the wiring harness so that I can immediately install my pamco and new ignition when it arrives tomorrow.
My god there are a lot of wires. Where am I going to put all this shit when I get the bike running again?
I'll post again tomorrow when I get the Pamco and ignition installed (and hopefully have the bike running again).
Any suggestions on ways to improve, or different directions to go in with my build will be happily welcomed. Thanks
clean up rear brake
Stage 3: framework
Seat
New rear fender
Stage 4: looks
paint
