All,
I have been researching alternative disc brake rear hubs for wire spoke wheels.
Finally, I found a "Talon" rear hub for a KTM MXer, which is narrow enough, and has a disc brake. This hub has bearings for a 20 mm axle (lucky!) and a width of approx. 150 mm. So plenty of space to fiddle around with spacers and caliper bracket.
It is light also, 1.5 kgs with bearings, meaning a wheel with aluminum rim and SS spokes will end up between 4.5 and 5.5 kgs. Disc, sprocket and caliper will all add to this, but a stock drum rear wheel is closer to 10 kgs...
This hub has no cush drive, but the stock drum brake hub hasn't either, so should be ok.
Talon says that they use 8 gauge spokes with this hub, so here comes my question:
Do you all beleive that a hub made for a 500 MXer, with 8 ga. spokes is strong enough for an XS?
Considering how an MXer is ridden, I tend to believe so myself, but I am interested in your opinions!
