sentricity
Ok, well I have managed to put this off long enough. I originally bought the bike in great running condition for $700 down in NC off a mechanic who didn't want to "mechanic" it
I chopped it into a brat(ish), '60s(ish) thing. It was fun, but time for a change.
Don't mind the model... My 5 year old ham.
I mounted up a '75 DT400 front wheel for the drum brake and 21" rim, turned all the lugs off the forks, lowered it 2.5", removed all the tabs from the triple trees and built some tight window bars.
The tank was an older aftermarket Frisco Sportster tank, the seat was made my me and upholstered locally in MN. I lowered the seat rail and bent forward the rear spring mounts and had Rebel shocks. I ran the 48 spoke stock 16" rear rim and a Shinko dual white stripe wheel.
My pride of that build is the horseshoe style "oil tank" under the seat that housed the battery, fuses and coil.
The engine was freshened up with rings, hone, valve job, XSJohn's (RIP) needles, seals and various hardware. I bead blasted the entire engine and painted the lower jugs for that Trump look.
The headlight is a '30s fog lamp and the taillight is a '40s Chevy pickup taillight. I painted it orange, and by accident, it ended up being a very close match to HD orange.... Ooops
