Tyler Jay
'78 7-plate clutch
Swapped to single long pushrod. Both balls in place.
New cable oiled.
Tried all sorts of left-side adjustment.
Pressure-plate and basket aligned correctly.
Bike is stuck in gear. Clutch is not disengaging and the amount of movement is equal to this video.
Should my plates be noticeably separating?
Like the video, is the clutch being pushed-out far enough?
When I removed the clutch plates, I noticed the friction plates were sticky and continue to have some resistance when detaching from the steel plates even after cleaning. SAE 20-50 was used last, should I try something thinner?
Also, the kickstart gear assembly is removed, does that have any affect on the clutch?
When I did have the bike running and put into first, I could release the clutch all the way out only for the bike to barely creep along so It didnt seem like the clutch was fully engaging.
Any help before I start buying all kinds of parts (like friction plates and push screw housing or a whole new clutch basket) would be great!
New cable oiled.
