DirtyErnie
Renaissance Hick
Here's a pic of the Heiden needles with a pair of stock '80-'84 BS34 needles for starters. I have the stock needles set to show how big of a tuning range is available on the Heiden's and just how bluddy long the things are. I also have a suspicion these needles are meant to work with their 2-into-1 exhaust.
Here's my setup: 653cc (stock), Shell #1 cam (Hoos mis-grind), BS34's, Heiden/ XS Performance 2-into-1 pipes into a 1.75" Cherry-Bomb muffler (It's loud, but the muffler gives me a lot of pipe length 'after the collector' and keeps exhaust velocity and inertia up.)
6/28 edit: Finally have made good progress with these needles. It turns out, I was running my valve lash wide (.006" int/.012" exh). When I set it a little closer to normal (.004" int/.007" exh) the added duration and overlap made the mix a bit richer. The last few changes I've made have been with a #47.5 pilot, 142.5 main, and I worked the needle leaner from its richest position. These guys have six tuning slots, and I've finally chased away the off-idle stumbles by lowering them to position #4. This puts the top of the taper about where the stock needles should be, but I know I'll have a mid-range lean bog once the temperature goes below about 70*. I'm hoping to be proven wrong about that, but I doubt it's going to happen.
Ultimately I think I'm going to end up with either the stock needles or the Canadian needles and a #140 or 137.5 main jet. I'm pretty sure these things are just too damn long in the low-speed taper. Going to re-visit the pilot jets and see if getting the lash closer to factory made those richer, too. Stay tuned.
