deadchef
xsbobblehead
ok, went out to reconfirm my timing. at idle it's at full advance. if i give it some throttle it advances further and then starts stumbling like normal. can't retard the pamco anymore.
granted, this thing hasn't run right since i got it but could this be the real reason behind the stumbling?
saw this article from another thread...
http://www.650motorcycles.com/CamTiming.html
it shows a way you can confirm the cam timing by just looking at the pin alignment for the advance mechanism. the article says it should be vertical.
here is where mine is at tdc...
can i assume i'm screwed?
