Yup - skip the PWK's.
Honestly the standard intakes are your best bet. I recently put on billet lengthened intakes on my XS, and gave up the vacuum barbs as a result. My carbs don't have the vacuum barbs installed right on them the way the 650 Central carbs do. He adds those.
I put my billet intakes on because I had them, and they were made specifically to match the porting done on my head. When I first put them on, I used a short section of silicone rad hose and pushed the carbs back about 10mm. I've since shortened the hose as a) the bike is running rich and I wanted to reduce the impact of the lengthened intake and b) with the carbs pushed back, I lost access to the air screw on the left carb.
The air screws on both the left and right carbs on the right side of the body, and pushing the carbs back put it right behind the frame downtube. So I couldn't reach it with a long screwdriver anymore. Pulling them forward a little bit has now let me see it again.
I'll drill my carbs for vacuum barbs this fall to properly sync them. Up to now I've just 'bench' synced them by making sure the slides are adjusted the same and move exactly at the same times.
You can actually reach both slides with one hand with the filters off, and feel them move together to confirm they rise at the same moment. Once I get to this point and set the idle at exactly the same amount (using a 7mm drill bit in the intake) and set the air screws, the rest I do by ear while riding.
My carbs on my bike from last weekend in Alabama (Barber's). This is with the longer intakes. I've shortened them now so you can't see the red hose at all. Need thinner clamps to do it right.
