desmodromic
I'm in the process of rebuilding my motor. I am doing the 5th gear overdrive, 82' transmission, as one of the mods. I'm not crazy about the looks of this overdrive gear, I'm used to changing gears in pairs. I noticed the overdrive does not have notches cut into it and the teeth are not tapered on the edge. Do you guys modify them? Anyone had any problems with the overdrive gear?
BTW the gear that is on the transimission is the overdrive, the one avobe it its the OEM
Thanks
Thanks
