In 1977 the gearbox was changed midway through the year. before and after model no IT3-271262. ...Read service bulletin posted above.
If you have an engine no before this, then the mikes 5th gear overdrive, (Part #05-0870), or the 5th main gear, (Part #05-0857), will not be a match.
If your engine no is after this, then mikes 5th gear overdrive, (Part #05-0870), and 5th main gear, (Part #05-0857), will be a match
Mikes reads so you buy the 22 tooth 5th main gear with the overdrive cog, but in reality if your 5th main gear, ( post 1977D IT3-271262), is in good condition then why replace it......... You do not have to replace it........... it is up to you............... Of course Mikes wants you to buy them both.
