At some point in your work, it may be worthwhile to confirm TDC, just for "peace of mind" - the "tool" is easily made from a spark plug shell, and the procedure is easy to find on this forum. On TCI motors like yours, the full advance point is NOT marked, like it was on earlier points ignition motors - I think because the TCI system was not considered to be adjustable in service. Recently, someone on the forum (I think it was 5twins) informed us that the full advance mark (40 degrees BTDC) aligns with the left edge of the small square cut in the left hand case cover. After installing your new ignition system, you may want to check full advance (approx. 3000 rpm) to ensure that it does not exceed this spec. (5twins, please correct me if I mis-remembered and have mis-stated what you said about finding the 40 BTDC point.)
