racerdave
^ Gone not forgotten ^
I'm looking but haven't found the specs for a Shell #1 cam, vs these specs for ths XS perf cam, I found these on Mikes XS. Can anyone help, advise;
XS Performance cam
TIMING SPECS
Timing at .040"Lift at Valve
Timing to be checked with zero clearance
see running clearance - lash below
INTAKE EXHAUST
OPEN 26 Degrees BTC 60 Degrees BBC
CLOSE 66 Degrees ABC 32 Degrees ATC
VALVE
LIFT: .420".420"
DURATION: 272 Degrees 272 Degrees
LOBE
CENTER: 110 Degrees 104 Degrees
LASH OR
RUNNING
CLEARANCE .006".006"
(Cold)
XSperformance Cam Kit for 1974-84 447/533 type XS650 Engines
( 36 tooth cam sprocket )
Part # 05-0025 Sold as a kit Only as shown above
XS #05-0025 XSperformance Cam Kit Includes
Cam, Performance Valve Springs and retainer kit
and premium valve stem seals ( 4 )
XS Performance cam
TIMING SPECS
INTAKE EXHAUST
VALVE
LIFT: .420".420"
LOBE
LASH OR
RUNNING
(Cold)
