CalsXS2
XS650 Guru
- Messages
- 1,006
- Reaction score
- 52
- Points
- 48
Ok. This is on my TX750. But it's my 72 XS2 carb's. I'm running pod's and a po cut off the pipe's. But the baffle's is still in there.
I'm trying to dial out some popping/crackling out of the exhaust. It does it mainly at idle, or low rpm.
The carb's are fresh. I just did butterfly seals too. From what I understand, this sounds like a pilot jet issue?? I've went from a #42.5, to #45, to #47.5. It did get a little better each time I think. It was hard to tell by the seat of my pants.
The bike has always started easy, and run strong under WOT. But I've had that little popping I'm trying to get rid of.
So today I put in a #50 pilot. Now it's hard to start, and spitting out of the carb's when I try to start it. I didn't get a chance to go on a far enough ride to really get on it to tell how it pulls.
I checked the plug's and they are black as can be. Real sooty looking.
I have my needle's set in the 4th position from the top. Do I just need to change that now. I'd have to say the popping is gone now. But again, it was a very short ride.
I have to have a special wrench for this dang thing to get the valve adjust cap's off. It's on the way. So I'm on vacation next week and will address that. But it has always run very good I think. Except for that little popping.
Am I any closer,, or farther away than I was before. Does it sound like I'm too big on my pilot now. Or do I just need to change my needle setting. Thanks.
