CoastsideXS650
Princeton Motor Works
I am having a difficult time getting my idle to sit right.
My motor is a 277 rephase with Pamco. I just shortened my advance springs and lubed the cam bushings with moly grease. They pass the snap test just fine.
My carbs are 1980 BS34's with brass floats.
Uni Foam filters and homemade pipes with the cheapo baffles shoved in the end.
137.5 Main, 45 Pilot, air/fuel screw 3 turns out
I recently rebuilt the carbs with new o-rings, throttle butterfly seals, set float height, synched carbs using manometer. Everything is working just fine. My only problem is the idle seems high. I have the idle stop screw turned out till there is no contact with the throttle lever and it still is too high.
I can kinda push the throttle lever back a little more with my thumb and the idle drops to a perfect purr. Its almost like the throttle plates don't have enough spring tension to them.
Am I supposed to double wind the throttle springs on the carbs? Could my throttle plates be slightly not seated completely?
The 3 mix holes are covered by the throttle plate when closed. Only the air mix hole is on the other side of the plate.
Im stumped guys.
Im stumped guys.
