XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 05-23-2013, 02:30 PM   #1
westonboege
westonboege's Avatar
Default XS650 Tracker Build (Counter Balance Cycles)
Just getting started on a new xs build for a local customer. This will be one of the first bikes ill be building under another direction. Should be a blast. Wont be anything too crazy. Just a simple clean cafe/tracker with a few custom parts... Should come together quick.
Fitted an 18" rear drum wheel to the stock disc swingarm and frame. Luckily i have the brake linkage, which was the hardest part to build on the last one I switched over... Front wheel is temporary until my new rubbers get here...
Got a bunch of parts ordered that should be here next week...
Cheers,
wes
BLOG - http://counterbalancecycles.blogspot.com/
STORE - http://counterbalancecycles.bigcartel.com/
westonboege is offline   Reply With Quote
Old 05-23-2013, 05:06 PM   #2
drewfunk
Purveyor of fine flannels
drewfunk's Avatar
Default Re: XS650 Tracker Build (Counter Balance Cycles)
Your builds always kick ass, this should be awesome.
1974 TX650
1982 Nighthawk 650
drewfunk is offline   Reply With Quote
Old 05-24-2013, 01:27 AM   #3
TwoManyXS1Bs
Ranch Wrench
TwoManyXS1Bs's Avatar
Curious what handlebars have you chosen?
(2) `71 XS1Bs - 1 'apart' bike, 1 a 'parts' bike
Just call me "2M", it's easier...
TwoManyXS1Bs is offline   Reply With Quote
Old 06-14-2013, 09:39 AM   #4
westonboege
Been a few weeks since ive posted. Went on a 1000 mile trip to vermont last weekend. On the way home got into some shit on an offramp. Guy in front of me hit the guardrail trying to dodge a shredded truck tire in the middle of the turn. I avoided it but hit some gravel on the side of the road and high sided my sportster. Little road rash and a few fractures in my foot. Have had alot of time to spend in the shop being immobile...
More updates will happen soon... Have most of the parts i need for this thing.. Should be able to get it running by next weekend...
-TwoManyXS1Bs- Bars are just some low rise tracker bars... if this bike was for me i would put something funky on it.. hahah
Old 06-27-2013, 12:33 PM   #5
westonboege
Got the seat pan made, covered in foam, and sculpted. Seat is out with Freddy getting some new clothes. Front tire is mounted, and I just removed the rear to get the rear mounted and balanced...
Got the muffler tab welded to the frame. Getting the hang of this TIG welding stuff...
Made a custom exhaust for this one... Starting to really like it. Getting ready to wrap the exhaust soon... should look nice...
Bike is coming together... Hopefully I get a few parts that I am waiting on and get her started by this coming weekend...
Old 07-01-2013, 07:24 PM   #6
westonboege
Hey guys got a question.... What is the bare minimum you need to start a motor? If I try and start it with just ignition switch and coil/ignition wired, will it destroy anything? Or do I need the voltage regulator?
Just want to see how this motor runs before I finish wiring everything in...
I was thinking if I wire a fuse in line to the coil I could protect it...
It's just late and I wanna hear it run... Hahaha
Old 07-01-2013, 08:52 PM   #7
Ketis
Ketis's Avatar
You can start it with just the coil/ignition hooked to a battery
Thats what im currently doing
Ketis is offline   Reply With Quote
Old 07-02-2013, 02:52 PM   #8
westonboege
Ok cool. I gave up last night and just decided to get the rest of the reg rec hooked up to be safe... Should have it going tonight...
Old 07-15-2013, 01:18 PM   #9
westonboege
Its all down to the wiring and a few last minute frame tweaks now. Spent most of the weekend sweating in my shop. Got the coil wired up and mounted correctly. Mounted the batt box. Got the turns wired in with the handle bar switches. Also got the speedo wired up and all dummy lights connected... This is my first harness from total scratch. Its coming out much better than expected...
Also got the brown seat finished. Its gonna look hot with the final paint...
Few more weeks now...
Old 07-15-2013, 02:48 PM   #10
scabber
XS650 Guru
scabber's Avatar
Nice job on the bike. Looks great like the seat. You really do nice work.
80SG 750cc 1 1/2 mikes comando exhaust. 2009 EX500 CVK carbs 38 pilot jet 138 main jjj needles Uni pod filters. Shell #1 cam RD springs ported head 17 and 32 sprockets. Progressive springs emulators Forodo springs clutches one piece rod bearing up grade. Brass swing arm bushings bolt up grade. Pamco E-advance ultimate coil.
scabber is online now   Reply With Quote
Old 07-15-2013, 04:55 PM   #11
TwoManyXS1Bs
Ranch Wrench
Westonboege, lookin' good, wish I was there to help, but mostly to learn tig, that one I haven't done yet.
So, I sent our Texas weather up there instead, should help with snowmelt.
Enjoyed your pics, but like others here, the eye wanders off to the backround. Do I spy an Atlas/Craftman 618 back there?
Old 07-16-2013, 06:43 AM   #12
westonboege
Thanks dudes... Ill always take the warm weather... even tho im sweating my as$ off lately..
TwoManyXS1Bs - you are right that is an old craftsman lathe... old but still does the trick for smaller stuff...
Old 09-03-2013, 08:11 AM   #13
westonboege
Hey guys, I know ive been pretty lazy on updating this page, but i wanted to make a little time lapse of disassembling and reassembling the bike. I took a couple hundred photos but it will take while to process...
I spent all last week marathon painting and assembling the bike, and took a few snaps as the new owner took it away to ride... Ill get some proper photos later this week...
Cheers!
Old 09-03-2013, 04:01 PM   #14
hotdog
XS650 Guru
hotdog's Avatar
Is that one of your seats.?
hotdog is offline   Reply With Quote
Old 09-03-2013, 05:02 PM   #15
westonboege
Yeah, it's one of my custom seats...
Old 09-06-2013, 08:43 AM   #16
westonboege
Took some more photos last night... Some came out good... too dark for my lens... hahah
Old 09-06-2013, 09:44 AM   #17
JP50515
XS650 Junkie
JP50515's Avatar
Looks good man!
...Shop Logic Customs...
1977 XS650 - Tc bro's Hardtail, Pamco, Shorty mufflers, BS38 carbs, pod filters
JP50515 is offline   Reply With Quote
Old 09-16-2013, 08:40 AM   #18
westonboege
Thanks dude... been alot of work!
Old 09-16-2013, 08:46 AM   #19
richardthemotorcycle1
XS650 Guru
richardthemotorcycle1's Avatar
Awesome looking bike, love those colors!
richardthemotorcycle1 is offline   Reply With Quote
Old 09-16-2013, 09:18 AM   #20
bt24
bt24's Avatar
What brand of mufflers do you have on it, they look great. The whole build looks awesome, you did a great job. The smile on the owners face kinda says it all.
Bryan
bt24 is offline   Reply With Quote
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
My Yamaha XS650 Street tracker Build by olddude13 olddude13 The Garage 233 03-29-2016 04:54 PM
xs650 build (my first) brat tracker??? Craigk47 The Garage 24 05-21-2013 09:23 AM
Counter Balance Cycles westonboege Shops 10 05-07-2013 07:59 AM
1972 Cycles&Quads Custom Build Cyclesandquadsxs72 The Garage 18 09-10-2012 09:24 PM
Primitive cycles latest build Primitive The Garage 4 10-23-2009 09:28 AM
Tags
tracker cafe counter balance
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
