CDNTX650
XS650 Guru
same mount hole spacing as the 4 pot. The bracket from pandemonium doesn't work with it. (holes aren't far enough out) With the mount on the outside of the original mounts on the fork leg, all I needed was some small washers to move the caliper closer to the spokes. like 1/8 inch. have to file out one spot on the caliper as the rotor is thicker than a modern one. I have a pad set with about 30% left. so not 100% if new ones will fit without losing a bit on the belt sander. No worries for me. Wifes bmw uses the same pads.
[/URL][/IMG]
[/URL][/IMG]
