I'm somehow still not clear on this. Let me start from the beginning again.
I have a'80 engine (TCI originally, but I did the PMA swap (banshee parts) and now Im running the NEW pamco with a capacitor and no battery.
According to pete's site, since I have an 80 engine, I needed to buy:
Points advance rod #14-0650
Breaker plate screws #14-0655
Advance locating pin #14-0653
Brass bushings #05-0032 (3)
and then from Mikesxs I bought this:
http://www.mikesxs.net/parts/img600/14-0903.jpg
So, you're saying that I DO NOT install the aluminum cap side first? So I install the right engine side first?
Or, am I installing the aluminum cap side first without ANY of the three washers (slotted/unslotted) and it will just be the bolt threads (this side has the advance pin already installed) alum. cap, lock washer, nut? That's it? And then I push the rod through and install the other side with the copper bushings?
