slade
It appears as if Mike's no longer has the high volume oil pump. Does anyone know where one could purchase one? I am installing an oil cooler.
at 119 euroes the price is nuts for a marginal quality pump.
I think I will just blue-print a new pump.
Maybe you have a special set of circumstances, but I can tell you that I am not aware of even one XS650 being raced in AHRMA road or flat track racing that uses a high volume oil pump. The factory race bikes in the '70s didn't use one, nor did the ultra-trick OU versions of these engines.
If a 65 - 70 RWHP XS engine can be held wide open at 8000 - 8300 RPM for as much as a minute around Daytona's road course using a stock oil pump with no evidence - ever - of an lubrication-related failure, I can't imagine any other use that would create an even more hostile set of conditions. Ditto at Willow Springs on 105+ degree days between turns 6 and 1.
So, as I say, unless you are doing something truly onerous to the engine, save your money.
I fitted a 50%+ oil pump I bought from The Tired Kraut back in 2010 after a crankshaft bearing and RHS top end failure. I hadn't owned the bike long and didn't really know it's history or even much about the XS650 in general at the time. Seeing as I was going the paper filter/cooler route at the same time I decided a bigger pump couldn't hurt and had to replace the original as it had a cracked rotor ring.
End result was the pump supplied was a beauty, spun freely with minimal clearance and shoves oil everywhere. End result is a quiet engine but I had to sort a few leaks at first.
I will try to find a site for "tired Kraut"
hes on german ebay and he does it both in english and german
