Sparky
While messing with my forward control mockup, I noticed the tach block off cap was loose. Turns out the entire thing was broken in half. Is that common? Can I just leave out the entire geared shaft? I won't be running a tach. Lastly, I searched and read about a washer that is probably now just floating around inside the case. Should I go ahead and pull the case cover off and remove that?
