XS650 Forum
Go Back   XS650 Forum > General Discussion > The Garage
Register FAQ Members List Search Today's Posts Mark Forums Read
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Topics
Threads in The Garage can also be viewed by Topic.
Reply
Thread Tools
Old 01-12-2010, 06:19 AM   #1
inxs
XSively Addicted
inxs's Avatar
Default Dell'Ortos and Bier
- over a few biers and bullshit-i dont drink -the topic turned to Dell'Orto carbs...was interesting so i started taking notes as i have thought about going there myself...i havent tried these so dont take this as gospel
- the general consensus was that PHF DD-destra or right and PHF DS-sinistra or left as 30, 32, 34mm are better suited for the XS, some have used 36, 38 40mm versions but found them over the top...get them paired DD and DS otherwise setting problems arise
- the 32 and 34mm versions had been successfully mounted in SE 650 and SR 500 manifolds, the SE 650 had the advantage that vacuum barbs are present
- for second hand carbs look for ducati or guzzi models
- lever choke not cable, and is only required on the LHS
- you want the models with the round plastic or alu cover, not the tubes, cables enter at 45° or 75°, some have side cable mounts and are better for space
- get the version with an accelerator pump
- brace against vibration
- use softer return springs
- get the 2 into 1 cable fittings as found on Ducati California III and Guzzi Le Mans IV
Some Info XS650 Dellorto
best dellorto handbook ive found scroll down the page to carb section
this old tractor some info here too…dont really find this too interesting tho
ducati meccanica interesting site...the following are found there
dellorto tuning guide
factory jetting guide
dellorto jetting/dellorto parts book
needles charts
setting float levels
factory set-up for singles
PHF parts list and diagramme
from stein-dinse.de
needle chart PHF
slides
jets
from dell orto
english version of manual found here
some settings
PHF32
Slide................60-3....50-3....50-3....50-3....70-2
Idle jet................50.......57.......55........... ......57
Main jet.............170.. ...125.....125.....135.....125-130
Atomiser............265......262.....265.......... .....262
Needle...............K16........K6.....K18........ ........K6
Starter jet...........75........75.......80............... ....
Needle Ventile.....250......250......250................. ..
Pump jet..............?.........35........35........... ........
Float........................................10g @ 18mm
...............PHF30........PHF36
Slide....................................50-3
Idle jet...........55.....................57
Main jet........125....................120
Needle..........K23-mid setting.....K5-top setting
Atomiser.......262....................262
Float............8.5g
- dont forget this was liberally lubricated with mind altering substances so reader beware
PHF36
PHF30
fear is temporary, regret is forever
inxs is offline   Reply With Quote
Old 01-12-2010, 06:35 AM   #2
jay760
jay760's Avatar
Default Re: Dell'Ortos and Bier
Now you are just trying to show how dirty my engine is
jay760 is offline   Reply With Quote
Old 01-12-2010, 06:39 AM   #3
inxs
XSively Addicted
inxs's Avatar
- just well abused - mate
Old 01-12-2010, 07:10 AM   #4
jay760
jay760's Avatar
I run 32mms on both mine, the 760's have been bored to 34.5mm which has to be done slightly off center( raised) about as big as you can go without the slide interfearing, with either a 180 or 200 jet, I know there is a big differance in the sizes but it was a long time ago I set them up and the bike is on the other side of the world. The 707cc's are standard 32mm with 190 jet( the ones that were left, I think a friend had the other ones) but won't rev past 6500 not sure if it's the ignition or just the fact it's a friday bike, probably the worst xs in the world ever.
Reply
Tags
carburetors, dell orto
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Copyright ©2000-2010, Jelsoft Enterprises Ltd.
Copyright © 2009-2010 XS650.com, Trav, LLC
