This could be a stupid question.
Situation:
-Engine in frame, no oil for about a half a year. Functioned fine before teardown. (nothing on the engine touched, bc if it aint broke...)
-chain/rear wheel not hooked up, still building frame bits
-foot clutch is hooked up, when actuated it moves the pressure plate about 1/8th inch or so. Plates are free when actuated and can be moved in and out by hand.
-when in gear and actuated, i can't spin the front sprocket by hand
-clutch alignment marks are fine.
I dont think this is right. It makes sense that if the clutch is working properly, when in gear and clutch fully depressed, i should be able to spin that front sprocket.
Is there a minimum amount the plates need to move to work properly? I'd think that being able to move the plates when disengaged would mean its right.
Or is this all fine...
Situation:
