hard_y_rd
XS650 Guru
Just wondering if anyone had successfully did this? I'm sure anything is possible with a welder. I woud like to see a thread or some pics on this. I did a search but came up empty.
I have done a lot of frames and I would think it would be easier to do than installing a hard tail. If you cut the frame below the curve on the backbone about 4" above rear motor mount and made the same cuts as you do for a hard tail. Use a ass end from another frame I think it can be done in three welds. If you are doing a brat the two bars were the seat sits has to be cut anyway so that would be done when you brat it.
Line up two frames and look at it.
Rich
