Ya. I had the little filter on the end of the hose. It kept falling off and getting dirty, so I switched to what 5twins did in the thread I linked. The filter let's air out and back in, but the filter grabs the gunk before being sucked back in. The valve just stops all inward flow all together and maintains a consistent internal pressure. Having the correct pressure also helps to let the seals work better, less leaks, apparently. I didn't have any leaks, but I can understand this.
