Patches
XS650 Junkie
Hugh-
I'm hoping you're reading the board right about now. I got a wild hair and took your advice and picked up a set of 34mm power jet Lectrons. I wanted to post this in the main board instead of sending a PM so other members that are thinking about lectrons could get this info as well. I know that I need 0-1 metering rods, but I was wondering if you had any info on which two into one cable to use, and what carb boots worked for you....? From what I gather these are supposed to be the easiest carbs in the world to tune, but any tips would be greatly appreciated. I have already read lectron's tuning guide, and it seems pretty straight forward.
Eventually once things slow down I should be sending you a crank and cam to get the "bumpity, bumpity" done to them for a 750 kit and these carbs.
Thanks in advanced.
Ryan
Thanks in advanced.
Ryan
