A better fuel filter?
Visu-Filter claims to be ethanol compatible.
"Housing: Clear PET (E-85 compatible)
Filter Media: Porous Sintered Bronze
Cap: Clear PET (E-85 compatible)"
mike
I used the same cheap plastic ones your showing on the Yamaha.
Used one like this on the chopper, and had the first one leak from the factory
The one teecat showed a link to seems promising though, might switch to that.(not on the chopper, the Yamaha)
I was searching for fuel filter threads last night and TeeCat's Purolator f10024 solution sounded good to me.
Problem- no one local had Purolator filters handy and the parts store people on the phone weren't all that helpful. I did a quick google cross reference check on the filter number and it's the fuel filter used for 1982 FORD trucks with the 4.9L 300Cu. In. inline six motor. Probably a lot of others too. Anyhow, the same unhelpful store had several in stock, and it might help some of you find one.
I like the idea of the Purolator f10024 I wonder if I want to have a little more room if I could run right petcock to left carb left petcock to right carb (1975 stock 650) I think it was posted on another thread ?
I have been using Visu Filters for several years and have never had a problem with them. However I did have an issue with the cheap generic filters.
I bought some F10024 Purolator filters. See pics. Way to fn big. Suggestions?
